MX3070 no backlight
  • Dark Helmet
    • May 2009
    • 843
    MX3070 no backlight
    Howdy folks
    Just for the knowledge bank,
    Had a MX3070 that had no backlight, you could see the buttons if you put a flash light on the angle and every thing worked.
    Swapped the entire panel, still no backlight. Replaced LVDS board and away it went.
    Try the $90 board before the $450 panel
  • sharphead
    • Aug 2009
    • 285
    Re: MX3070 no backlight
    I had a 2630 and the flat cable onto LVDS was slightly on seated. Worth checking that also. Same issue no back light
