MX-FN27N Connection Harness
  • xring1958
    • Mar 2016
    • 166
    We want to move one of the older FN-27 finishers to a newer machine that has the new connection harness I don't see a harness listed in parts guide has anyone ordered one of these and have the Part Number Thanks
    Re: MX-FN27N Connection Harness
    depends on which newer model you are trying to hook it up to
    • xring1958
      • Mar 2016
      • 166
      I want to connect to a MX-5070V they changed the harness connections a few years ago.
        then it probably won't work.. different harness .. different board ...
        different schematics for pinout
        check pinout for each...
        IMHO buy a different finisher .. the correct one to match the copier.
        • xring1958
          • Mar 2016
          • 166
          We actually did it once before but we had a donor/ parts finisher so we didn't need the Part #
          • branjake
            • May 2016
            • 7
            Look at MFP-TB-1717R2 Part #DKIT-0474DSZZ
            • xring1958
              • Mar 2016
              • 166
              Thanks a bunch. They aren't giving them away!
              • xring1958
                • Mar 2016
                • 166
                Thanks again we got part in and it worked. I was expecting a cable not a adapter board but all is well.
                • branjake
                  • May 2016
                  • 7
                  No problem, we have used those boards multiple times so far.
                  • Squiggy
                    • Jan 2020
                    • 41
                    will these work on the 1 series also?
                    • Prints Charming
                      • Aug 2019
                      • 189
                      Yes. Any V series model and the newer models ending in 1 all support the appropriate Interface Kit to allow the installation of a non-N model option.
                      • Squiggy
                        • Jan 2020
                        • 41
                        Excellent news
                        Thank you
