MX-6500 Power Status Flashing White
  • oeshuron
    • May 2008
    • 259
    Mx-6500 status led flashing after customer power cycled.swapped mfp board with working board and still wont come ready. Display status flashes white.
  • oeshuron
    • May 2008
    • 259
    Re: MX-6500 Power Status Flashing White
    Had another machine doing something similar that ended up being the low voltage power supply so going to grab that next
    • mojorolla
      The Wolf
      • 2616
      Pull the cable on the HDD and see if it will give you are error. The HDD is the final device in the boot sequence so if you do not get an error, look at MFP board or SATA chip.
      • oeshuron
        • May 2008
        • 259
        Replaced Sub DC PWB and resolved the issue. Reset system to factory defaults and updated firmware just in case.
