Sharp MX-6070V with the COVID Curse
  • best-tech
    Master Technical Support
    • Nov 2014
    • 47
    This MX-6070V has been idle for several months, I guess suffering from COVID. Customer fired-up and getting a L4-35 fan motor trouble. Fan works in diagnostics...any thoughts before ordering the PCU?
    L4-35 Fusing cooling fan R trouble
    Trouble detection PCU
    Cause
    Fusing cooling fan trouble.
    PCU PWB trouble.
    Connection trouble of the connector and the harness
    Check & Remedy Use SIM6-2 to check that the fan is actually rotating.
    Replace the fusing cooling fan.
    Replace the PCU PWB.
    Check connection of the connector and the harness.
  • copiertec
    • Jan 2016
    • 2211
    Re: Sharp MX-6070V with the COVID Curse
    LOL... COIVID, I wish it was that easy to make a new sale! Searched the site could not find any bulletins pertaining to your code. Maybe a new fan? before PCU? I know it works in diagnostics, but maybe there is a little drag on the motor possibly?
    • OlliK1969
      • Nov 2016
      • 311
      Hi
      Sharp Germany:
      Phoenix series / feedback from the field:
      - What can be a possible cause for the error display L4-35 be?
      - Paper clip on the DSPF PCB
      - L4-35 display although the "Fusing cooling fan" is OK.
      - Short circuit on DSPF-PWB causes this error message.
      Response level TPM feedback:
      In one case there was a paper clip on the DSPF-PWB, which caused this error display.
      Removing the bracket from the circuit board fixed the error.
      best regards from Germany
      • best-tech
        • Nov 2014
        • 47
        Thanks all. Will keep you informed.
        • best-tech
          • Nov 2014
          • 47
          Update on the COVID curse L4-35 error. Replacing the PCU board fixed the problem.
          • Dcopyman
            • Apr 2020
            • 34
            had the same problem and new PCU pwb fixed issue also
