I have a strange issue with a MX-3140N, no DSK. 1.) I am unable to access the settings page on the control panel, it just goes into, "please wait' and nothing happens. 2.) I can't login as admin via the panel or webpage and service_login page A) I have done the dipswitch to access password and service reset, they complete but i am still unable to login even with the password reset. Also, I am unable to print any pages from service mode, ie, sim 22-6, 64-1,5, etc..nothing happens. All firmware, emaunual, watermark reinstalled and up to date. Any ideas? MFPc pwb or HDD?
MX 3140N unable to login as admin/service or list prints
Re: MX 3140N unable to login as admin/service or list prints
I had this happen on a similar machine and it was the SD card. Worked fine after replacing it. -
I forgot to mention, I replaced the sd card, but I cloned it off of that one so that could be an issue. I will try cloning from another sd card.Comment
Try a clean clone SD first but if no help would be HDD.Comment
FYI for Sharps that are UNABLE to print at all, you can extract pretty much all the good reports (22-6, job log) to a USB drive using SIM 56. It will give you error codes and an idea of what the issues are.
Failing to plan is planning to fail!!!Comment
Thanks again for the insight, it was the HDD, replaced it and all is good. I could not print out any 64 and 22 sims,the client said color was off, boy was it. A few MK kits and a calibration colors back on track.Comment
