Ar-m450 feeding problem
  • swagreis
    • Jun 2008
    • 92
    i have a problem of feeding in the first cassette only
    i changed the 3 feeding rolers but it also the same
    the paper sometimes passed in most times doesn't go out from it
    anyone can help
    thanks for all
  • bilyahn
    • Dec 2006
    • 1470
    2 things to check on. There is a small clutch cylinder on the seperation roller that will sometimes stick causing you some issues mainly the paper will not move out of the tray. The other is the small guide just after the feed rollers can become warped but generally you will have paper feed out of the tray.
    Good luck.
