MX3060 extended lan
  • joe_vanacker
    • Dec 2016
    • 28
    MX3060 extended lan
    Hello,
    with the extended lan card there is no default gateway. is it possible to change this so there is a default gateway?
    regards.
  • Prints Charming
    • Aug 2019
    • 189
    Re: MX3060 extended lan
    No default Gateway is possible on the extended LAN.
    Some other restrictions on the extended LAN are No PC Scan (TWAIN), No WSD and the Job Log cannot show differences in source network.
    • mansart
      • 855
      Just out of curiosity....
      What is the "extended lan" option?
      I'm in the USA market and not familiar with this option. Is its purpose to put a machine on two separate networks?
      • Prints Charming
        • Aug 2019
        • 189
        Yes, there are options to install a USB-Network dongle to the rear USB Port and once enabled you'll see 2 Network Menus in system settings.
        Have a look at any current model printer brochure to see the details.
        • mansart
          • 855
          No such option in the USA market
          • OlliK1969
            • Nov 2016
            • 312
            Hi
            -UE300)
            Only for Griffin2,Phoenix2+NeoIT2
            best regards
            • donwito
              • Apr 2021
              • 2
              Originally posted by OlliK1969
              Hi
              -UE300)
              best regards
              It happens so that I have a TL-UE300 adapter so I've decided to give it a try with Sharp MX-6071.
              I've plugged it in to the back USB port and nothing. No additional network menu. Rebooted the machine, still nothing.
              Is there something a Sharp dealer will have to unlock first, before it starts working? Or am I missing some configuration steps?
              Thanks!
              • spanky
                • Sep 2012
                • 468
                See sim 26-33 in the MX-6071 service manual
                • Prints Charming
                  • Aug 2019
                  • 189
                  Correct.
                  Extended LAN must be enabled first.
                  Once done, you will see a new Extended LAN network option within Network Settings menu where you can configure the second network.
                  Under Security Settings, there's also a Port Control option for the second network as well.
                  A great feature of the Extended LAN is that you now can have 3 connections to the MFD instead of just 2.....Wired, Wireless Access Point and Extended LAN.
                  • donwito
                    • Apr 2021
                    • 2
                    Originally posted by Prints Charming
                    Correct.
                    OK, so time to mail my sharp dealer. Thank you both!
