MX3071 C4-00
  • bigdaddyooo
    • Dec 2014
    • 211
    MX3071 C4-00
    So I have a machine I took out of an office and swapped because of this very intermittent issue. I'm using it in my office and it just had a C4-00 on the display. BUT..I get a 23-2 and there is no C4-00 since the beginning of August but I do have P_ON jams and DOP jams. When the C4-00 happens it DOESN"T list it in the 23-2 but it does have the jams listed at that time of the C4-00. Checked the MC and TC pwb's, all look good and connectors are seated fully. Any suggestions?
    Are you the police? "No ma'am, were musicians"
  • zenkinsw
    • May 2019
    • 5
    Re: MX3071 C4-00
    Might be same as the older models, have you try a new PTC yet? if yes could be voltage leakage on the PTC holder need to be replace.
    I believe the paper jams due to device immediately stop when the C4-00 error prompts.
    • copiertec
      • Jan 2016
      • 2205
      Re: MX3071 C4-00
      have you installed a new ptc unit?
      • bigdaddyooo
        • Dec 2014
        • 211
        Re: MX3071 C4-00
        Absolutely, twice actually. Removed and reinstalled MC pwb and TC pwb. Machine date is early 19 so the ptc holder is the newer one. VERY intermittent issue that is what sucks. Wish I could have a hard failure to remedy it.
        • copiertec
          • Jan 2016
          • 2205
          Re: MX3071 C4-00
          Next, if you have eliminated any kind of drum charge shorts, according to the service manual replace these following boards 1) PTC PWB 2)TC PWB 3) PCU PWB.
          • bigdaddyooo
            • Dec 2014
            • 211
            UPDATE....Re: MX3071 C4-00
            Replaced TC pwb and machine has not coded since. We will see.
            • copiertec
              • Jan 2016
              • 2205
              Re: UPDATE....Re: MX3071 C4-00
              How has this series been treating you? Are the fusers any better then the prior series?
              • Charfamine
                • May 2020
                • 14
                Re: MX3071 C4-00
                You have to replace the PTC holder and not the PTC. LHLDZ2540FCZ3
                • bigdaddyooo
                  • Dec 2014
                  • 211
                  Re: MX3071 C4-00
                  [QUOTE=Charfamine;1591264]
                  • Tech2002
                    • Aug 2008
                    • 334
                    Originally posted by Charfamine
                    Re: MX3071 C4-00
                    Or first try cleaning the PTC holder from any debri that might be a cause for a weak or bad connection.
