Toner Pipe units 5141
  • xring1958
    • 166
    Like most of you we have had lots of decomposing toner pipe seals on 10 series machines 3110 3610 2610. Have any of you been experiencing this with the larger units like MX 5141 etc. We are starting to see toner buildup in the rear of the machines and this seems a likely culprit.
    As always any input is appreciated.
  • mojorolla
    The Wolf
    • 2550
    Re: Toner Pipe units 5141
    Not 100% sure on the 5141 but on the 4111 / 5111 they actuality change the type of plastic used for those tube. The reason was toner clumping and excessive toner in dv issues. Also have issues with drum grounds and the filters atop the dv unit.
    • copiertec
      • Jan 2016
      • 2172
      Yes, the same issue with the seals deteriorating over time. Here is the tsb, same as the 10 series.
      MFP-TB-1477R Toner Pipe Mod.pdf
      • JLSam
        • Jun 2015
        • 601
        LMFAO, I just had this issue too.
        I remember taking out the magenta process and seeing it FULL of cyan toner, and I'm like "WTF". Take out the cyan and it is also jam packed with Black Toner. Looked at the back, and there was a huge ass gap where the seals should be. I was livid, because I was only supposed to change the magenta drum/charger/blade according to the last tech. Had to wait for the part and drive 30 sometimes miles again. So that's three visits, 60miles round trip, total of 180miles. Bruh...
        Good news is that it is EASY to replace. 3 Screws, pull out, and insert new part.
