Sharp MX-C402SC Hard Drive
  • driveraider
    • Oct 2020
    • 5
    I recently acquired a MX-C402SC and I am not sure how old the machine is. Since this machine has a HDD installed, I want to make sure I have a backup of it when it fails. I am way more computer savvy compared to copier savvy. So I should be able to do a bit-by-bit copy of the drive to a new one without issue. Does this machine require software loaded when a new blank drive is installed? I believe the answer is yes, which is why I am considering just cloning the existing drive. If it doesn't require software from Sharp to setup that is even better. Speaking of new drives, any reason besides cost not to put an SSD in it? There is currently an 80G drive installed now and a 120G SSD is less than $30. Thanks for the help!
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp MX-C402SC Hard Drive
    All Sharps S/N will have the date of manufacture; first digit (left most significant) is the year built, last digit (right most significant) is the month it was built.
    • driveraider
      • Oct 2020
      • 5
      My SN starts with 19 and the last two digits are 00. I thought sharp stopped making these in 2018.
      • ZOOTECH
        • 3375
        The 1 indicates built in 2011; the 0 is either the first or tenth month (never could figure that out).
        • driveraider
          • Oct 2020
          • 5
          I think I figured that out. The serial number on the machine vs the web interface is slightly different. The machine doesn't have the two zeros on the right. The last digit is 8. So Aug 2011. What is the easiest way to check the FW version? In SIM 22-05 perhaps?
          • ZOOTECH
            • 3375
            SIM 22-6 will give a nice printout of FW, options, supply counts, jams and errors.
            • driveraider
              • Oct 2020
              • 5
              Awesome, thank you! How old is the firmware that I am running?
              ICU(Main): 04.02.N1
              ICU(Boot): 01.03.N1
              • driveraider
                • Oct 2020
                • 5
                What is the latest FW for this copier?
                • mansart
                  • 855
                  Yours is current....
                  ICU MAIN 0402N1g0
                  ICU BOOT MAIN 0103N10a
                  DESK MAIN 0101F000
                  FINISHER MAIN 0103F000
                  PCU MAIN 0111F000
                  DSPF MAIN 0101N100
                  SCU MAIN 0101N100
                  FAX2 MAIN 0104P200
                  UPDATE NORMAL 0102F100
