H5-02
  • tomson25
    • 104
    [Error Code] H5-02
    My ARM206 machine after switch on ,scanner lamp continually on for 5 min then getting an error H5-02, what could be the problem
  • mansart
    • 852
    Re: H5-02
    • Description: Fusing thermistor abnormality detect. Fusing thermistor temperature transient abnormality (Paper winding)
    • Causes: Paper wound around the fusing roller. Fusing pawl abnormality Fusing unit installation failure
    • Remedy: Check for jam paper in the fusing section. (paper winding, etc.) Check installation of the fusing unit. Check the fusing pawl. Clear the trouble with SIM 14.
    • moose55
      • Mar 2017
      • 143
      Re: H5-02
      What have you done? Could be just needs to be reset? May need the paper around the roller removed? We really need something to go on here? With no troubleshooting list it appears you just turned the machine on, got the error, then posted here? We need a little help if you would like us to help you? Not meaning to come across snarky, but we need a little help from you end please?
      The Moose is loose!!
