MX3070N....how is this possible??????
+ More Options
Posts
  • mansart
    • 852
    Below are two status messages I recieved from a MX3070N. (full Status Messages attached )
    10Oct2020_R.pdf 10sept2020_R.pdf
    First dated Sept 10, 2020 and the second Oct 10, 2020.
    The meters have gone DOWN
    The machine display shows the lower meter?????
    How is this possible?????
    Sept 10,2020 Received status report....
    2020/09/10 11:28:38
    Device Name: Sharp Printer
    Device Model: MX-3070N
    Serial Number: 6511877400
    Machine Code:
    Current Device Counter Information:
    Black & White Copy Count = 222044
    Two Color Copy Count = 0
    Single Color Copy Count = 1
    Full Color Copy Count = 27751
    Black & White Print Count = 62508
    Full Color Print Count = 36188
    Black & White Total Print Count = 284581 Two Color Total Print Count = 0 Single Color Total Print Count = 1 Color Total
    Print Count = 64008
    Oct 10, 2020 Status report
    2020/10/10 15:19:54
    Machine Code:
    Black & White Copy Count = 150105
    Single Color Copy Count = 0
    Full Color Copy Count = 17737
    Black & White Print Count = 38750
    Full Color Print Count = 29906
    Black & White Total Print Count = 188881 Two Color Total Print Count = 0 Single Color Total Print Count = 0 Color Total Print Count = 47700
  • tsbservice
    Field tech
    • 7965
    Re: MX3070N....how is this possible??????
    Call them to read counters from copier atm or visit it onsite if possible. There is small chance automatic system readings get corrupted.
    • mansart
      • 852
      I've been on site, the display meter shows the lower count.
      • tsbservice
        Field tech
        • 7965
        Higher meter count mistakingly reported?
        • copiertec
          • Jan 2016
          • 2191
          Now that's interesting! No chance that machine has gone though a a space-time continuum vortex of some sort by chance? It may need more garbage to feed its Flux Capacitor to bring the meter back to the future!
          • mloudy
            • Oct 2015
            • 775
            Is this machine registered in MICAS where you might be able to see when the meters went down?
            I wonder if other counters dropped like maintenance and feed counters.
            • mansart
              • 852
              Not on MICAS
              I just get monthly emails.
              The number of inserted toners remained constant
              • tmw
                • Dec 2013
                • 256
                What does sim 22-01 say ? Does it have the original count ? I wonder if someone was fooling around & cleared the count in sim 24-6 or 9. Not that it makes much sense that someone would be in there in the first place.
                • mansart
                  • 852
                  22-1 changed as well.....
                  What didn't change are the paper tray counters.....
