star 38
  • star38
    • Jun 2009
    • 8
    star 38
    please help, having trouble in scanning to desktop from sharp 4070N. PCs connected with Wi-Fi network are nor receiving scanned image from the scanner, but no issues with PCs connected with wired network.
    • 37483
    Re: star 38
    I have seen that exact problem in the office where I used to work. Turned out to be the USB WiFi adapter that was being used. Laptops with built in WiFi worked fine. Try connecting using a AP extender instead of a USB adapter.
    • star38
      • Jun 2009
      • 8
      Re: star 38
      Noted with thanks, let me try.
      • bilyahn
        • Dec 2006
        • 1470
        Re: star 38
        Also check your network settings. If the networks are using 2 different subnets then that may be your issue or if the wireless is on a guest account that would also prevent scan from working. Have this issue at one of our clients on a regular basis funny thing is print works fine but scan won't
        Good luck
        Bil
        • mojorolla
          The Wolf
          • 2608
          Re: star 38
          Are users connected via WiFi-direct OR infrastructure mode? Does the customers network have a wireless bridge enabled, gateway the same on both devices....?
