Sharp MX-5001N firmware needed.
  • Smarttowers
    • Oct 2020
    • 6
    I am new to the forums and would appreciate any help with getting firmware for the sharp MX-5001N copier. I purchased this machine from a government auction and the hard drive was removed. I am very computer savy so thought not a big deal I would just put a new drive in. That part was easy but sadly after the machine finished formatting the drive it came up with a incorrect firmware error. I now need to get the firmware but was told by sharp that they couldn't provide it. I contacted the company that originally sold and serviced the machines and I am outside their service area. I am hoping a kind tech on the forums can assist me with this matter.
    If there is a way to install a new drive without a new firmware would be ideal but the service manual doesn't mention this issue about firmware with a new drive.
    Really appreciate any assistance in the matter.
    • 16402
    Re: Sharp MX-5001N firmware needed.
    Making a small donation to the site will greatly help you get what you need. Good luck.
    • Smarttowers
      • Oct 2020
      • 6
      Thank you for letting me know about the donating. I was more than happy to donate to the forum. Hopefully my donation will help the site.
      • romang
        • Aug 2011
        • 72
        What was the exact error code you are getting?
        • mansart
          • 852
          If it came from a government agency...it may have a security kit installed. MX-FR11U
          Which means a special firmware. Even if the firmware works the ADMIN password may have been changed and I don't believe there is any recovery.
          • miller01123@gmail.com
            • Jun 2019
            • 55
            Was it a blank hard drive? If not, you need write 0s to it.
              or just low level format ... partition and load.
                • Jun 2019
                • 55
                I use dban and use the single pass erase. I believe you need at least a 320 gig hdd
                • Smarttowers
                  • Oct 2020
                  • 6
                  I wiped the partition tables so the MFP thought it was a new drive. I got past the formatting part and then it gave the firmware error.
                  The error is:
                  Version Check
                  IcuM ROM UNUSUAL
                  • Smarttowers
                    • Oct 2020
                    • 6
                    How can I determine if it is equiped with the MX-FR11U?
                    Want to thank everyone for their assistance with this.
                    • Smarttowers
                      • Oct 2020
                      • 6
                      After the hard drive was inserted and it did its thing to it the error is:
                      Version Check
                      IcuM ROM UNUSUAL
                      Before I inserted the hard drive the error was:
                      Version Check
                      IcuM: HDD Trouble
                      I put a partition free hard drive in it, after a few minutes of what I assume was formatting I got the ROM UNUSUAL error.
                        • Jun 2019
                        • 55
                        Also, if it does have a security kit it will say FR11 or FR11U on the ROM on the MFP. You will need the firmware for the security kit. You may have to do an Emergency Update if you can't get into the sims. There is a dipswitch on the MFP that says update.
                        • ZOOTECH
                          Senior member of CRS
                          • 3375
                          If you can get into the Simulations, 22-10 will give configuration and options of machine.
                          • Smarttowers
                            • Oct 2020
                            • 6
                            I'm unable to get into the sims currently. I think it has to do with the firmware issue currently.
