MX-4071 Toner Levels
  • kdr363
    • Apr 2019
    • 64
    When viewing the machine info from MICAS, I can see the toner levels in one percent increments. But, when on-site, all I can see is 25% increments. I've looked through System Settings/SIMS, but haven't found a solution. Soft-switch? Sometimes, a toner cartridge feels very close to empty, but don't want to throw away good toner. This question pertains to most new Sharp models, not just the 4071.
  • Dark Helmet
    • May 2009
    • 858
    Re: MX-4071 Toner Levels
    Wish Canada could get MICAS.
    When i setup my machines i set 26-69 A=1
    This turns off the preparation alert.
    Every copier ive checked in Sim 22-14 will always have +1 Installed, 0 Near end, and number of used toners.
    IE Installed 5, Near end 0, End 4
    With the auto ejection system the toners should be completely depleted.
    • mloudy
      • Oct 2015
      • 791
      MICAS Mobile will show you the life of the toners in 1% increments.
      I wonder if a machine sold through Sharp Canada could be registered in MICAS? Have you heard a reason why Canada doesn't have MICAS?
      I contacted our SEC Service Rep about a MX-5051 dumping yellow DV as I couldn't find any documentation on it. He sends me an e-mail with photos and tips. A few days later someone on here posts a bulletin from Sharp Canada (maybe you?) about this with much more info that I was given. He may have even sent me two of the same photos. I don't understand the disconnect between countries. I have ran into this before with bulletins from Australia that addressed a problem that seemed to be top secret here.
      • mansart
        • 855
        My opinion here.....
        I've seen this many times as well. I believe because the USA is such a litigeous country. The vetting and/or approval process to release anything here probably requires many more "rubber stamps", than say Canada or Austrailia.
        • Dark Helmet
          • May 2009
          • 858
          Blame the french .
          • mttech
            • Mar 2014
            • 127
            If you print out a 22-6 it should show the toner levels in the smaller increments. Should be located towards the end of the maintenance and usage counters on page 1.
            • kdr363
              • Apr 2019
              • 64
              No, it shows them in 25% values. So does SIM 22-14. So does the home button double tap.
              • mloudy
                • Oct 2015
                • 791
                Circled shows Life of the toner which is what has been used, not Residual or Remaining.
                • mojorolla
                  The Wolf
                  • 2630
                  SIM 26-69 set value G to 0. This sets the MIB reporting increment to 1%.
