Off Lease MX 3140N unable to access IP (System settings)
  • copiertec
    • Jan 2016
    • 2211
    We received an off lease MX-3140n and I am unable to access the ip adress on the copier as system settings is disabled. So far I tried;
    1) resetting dip switches on mfp
    2) 67-17
    3) hdd swap
    Thanks in advance
  • JLSam
    • Jun 2015
    • 605
    Re: Off Lease MX 3140N unable to access IP (System settings)
    Question: Did 24-30 work?
    Sent from my GM1917 using Tapatalk
    • copiertec
      • Jan 2016
      • 2211
      I will try, JLSam.
      • copiertec
        • Jan 2016
        • 2211
        Just accessed 24 sims but no 30.
        • JLSam
          • Jun 2015
          • 605
          No, when you did the dip switch, were you able to go to 24-30 to reset admin pass?
          • copiertec
            • Jan 2016
            • 2211
            Yes.
            • mansart
              • 854
              The linked thread below has your answer......
              Copytechnet
              go to entries starting 6Nov19
              • mojorolla
                The Wolf
                • 2627
                2) 67-17
                3) hdd swap
                Thanks in advance
                When you say "disable" do you mean the icon is missing from the op panel ? You can add the icon back by customizing the home screen.
                As to the dip switch reset, remove the outer cover and the MFP board will have a metal cover over it. There will be a rectangular cutout in the cover; the dip switches are behind this cutout.
                • copiertec
                  • Jan 2016
                  • 2211
                  I have tried all the suggestions, thank you, reset dip switches, searched for its ip on the network, set home screen back to defaults, etc. I am going to swap out mfp pwb and see if that resolves the issue.
                  • mansart
                    • 854
                    "searched for its ip on the network".....when you press settings.....on left of screen do you see an item labled "Status"?
                    Press it then select Network Status....scroll down in main window, approx one third of the way down you should see the machines IP address.
                    For example 192.168.168.40
                    From there set your PC to 192.168.168.50, then browse to 192.168.168.40/service_login.html
                    • copiertec
                      • Jan 2016
                      • 2211
                      I'm going to do that, turns out the internet in the warehouse is not working properly, says there is connection, but when we tried to access other copiers webpages, it says it was unable to connect. I am hoping that by Monday the network in the warehouse it working, then I will try with advanced IP scanner and go from there. I will keep you posted on the results.
                      • mansart
                        • 854
                        If machine is set to Static IP it won't matter. You need to go to Status...Network.... and look at the IP setting currently assigned to machine
                        • copiertec
                          • Jan 2016
                          • 2211
                          Thanks mansart, I will give it a look. I appreciate the help.
