Mx-3070N Beeping
+ More Options
Posts
  • Demon33
    • Jan 2019
    • 38
    [Misc] Mx-3070N Beeping
    Hi,
    I have an MX-3070N that we bought used. It makes a little beep when I turn on the main switch, when I turn on the switch on the operation panel & when it comes out of sleep. Occasionally we can hear it when it's sleeping without it working. (a bit like an alarm system that needs a new battery)
    So far I have done a factory reset, flashed the firmware (normally & emergency) & copied a clone from another machine. I also noticed when comparing with the other machine that the dip switches had been changed. So I tried to change them to default but without success.
    It beeps even if I remove the fax, finisher & leave the network disconnected ...
    Apart from the beep, the machine works perfectly.
    I'm starting to run out of ideas & I think sharp too.
    Any idea ?
  • mojorolla
    The Wolf
    • 2629
    Re: Mx-3070N Beeping
    You can turn off pretty much all sounds in System Settings logged in as Admin.
    You can also unplug the speaker as I do not believe Sharps give a speaker error.
    • Demon33
      • Jan 2019
      • 38
      Thanks for the reply
      I tried to turn off the sounds in admin but it don't change anything for the beep.
      As for the speaker , I will try to find out where it's comming from. I have no idea where is that speaker. I never heard a sharp making that beep. It's not from the touch panel & not from the fax speaker.
      I just searched the parts manual & I saw an option from Japan with a speaker but I'm in canada & the machine comes from the US.
      Thanks again.
      • mttech
        • Mar 2014
        • 127
        The only time I have seen this is when the copier was plugged into a UPS. The UPS was making the beeping sound whenever the copier first fired up.
        • Demon33
          • Jan 2019
          • 38
          Thanks everyone for the help.
          I have found a "wave ID" card reader inside the machine that was making the beep.
          Good to know!
          • JR2ALTA
            • Feb 2010
            • 2033
            Good to know!
            That's funny.
            • lenovos
              • Oct 2012
              • 141
              Thank you I just had the same issue. I bought a used machine as well and my board was mounted near the front USB port. Thank you for p[osting.
              • kdr363
                • Apr 2019
                • 64
                I'll bet that it has a usb card reader hidden under the front left cover of the ops panel.
