MX2640 jamming
  • Leebs14
    • Feb 2014
    • 457
    [Jamming] MX2640 jamming
  • copiertec
    • Jan 2016
    • 2192
    Re: MX2640 jamming
    does it happen from different trays? ps unit?
    • danny464
      • May 2019
      • 81
      Re: MX2640 jamming
      does single sided printing work fine? When you replace the right door did you also replace the gear in the bottom right of the door or did you use the same one? What about the gear inside the MFP that turns that gear?
      • Leebs14
        • Feb 2014
        • 457
        Re: MX2640 jamming
        Honestly never tried it from tray 2
        • Leebs14
          • Feb 2014
          • 457
          Re: MX2640 jamming
          No just changed the door and refitted the gear, it all looked ok and the machine only has about 200k on it
          • danny464
            • May 2019
            • 81
            Re: MX2640 jamming
            I would try replacing that gear and maybe the other one too. I remember we were having a double sided printing issue some time ago and it was caused by that gear.
            • Leebs14
              • Feb 2014
              • 457
              Re: MX2640 jamming
              HI there, It seems it was that gear, the white one on the side door. I fitted another gear and it hasnt missed a beat. I have checked the old gear and cant for the life of me see anything really wrong with it, but the customer has just run a 3500 double sided print job and it has worked perfectly.
              Thanks for the advice
              • danny464
                • May 2019
                • 81
                Re: MX2640 jamming
                Glad it worked!
