PPD2_FIN - MX-M565N w/FN11
  • oeshuron
    • May 2008
    • 259
    Like title states getting PPD2_FIN jams with FN11 on MX-M565N. Outside of checking entrance solenoid on paper pass any other suggestions? No special firmware for MX-M565N and FN11 that I see.
  • mansart
    • 852
    Re: PPD2_FIN - MX-M565N w/FN11
    Check out this thread....may help
    • mansart
      • 852
      Here is another.
      • oeshuron
        • May 2008
        • 259
        Yes I seen the first thread relating to solenoid. The second thread relates to a different finisher same with the provided solutions. Not saying it's not a sensor though it's intermittent.
        • articcat182
          • Nov 2014
          • 24
          Had this too, beat our heads against a wall for a while.
          Ended up being replacement of the finisher PWB took care of the issue.
          • mojorolla
            The Wolf
            • 2627
            There was a retrofit for the actuator springs in some paper pass units. You can also put an extra loop on the actuator spring to resolve this code.
            With a code of PPD2, the entrance solenoid and PPD1 would appear to be working....where does the page stop in the paper pass?
            • jon jennings
              • Aug 2011
              • 51
              Check the upper guide on the RB. the hinge will break and cause this trouble.
              • JR2ALTA
                • Feb 2010
                • 2033
                for me 90% of the time it's a corrupt print job. Needs to be rebooted.
                • Dcopyman
                  • Apr 2020
                  • 34
                  Replace clutch on upper right back side of finisher.. this has fixed over 10 machines with same issue
