Does anyone have 3070-6070 fuser rebuild guides?
  • JR2ALTA
    • Feb 2010
    • 2017
    Has anyone come across (or made) like a full color PDF of the step by step rebuild for the belt kits? I know sometimes in training you'll get these in your class documents. The manual's "pictures" really suck. Looking to hand them out to techs since swapping fusers is getting expensive and they're always backordered.
    Thanks in advance.
  • mansart
    • 851
    Re: Does anyone have 3070-6070 fuser rebuild guides?
    3070 fuser rebuild.pdf
    Here is one I started....Got interrupted to figure out who ordered the 1-ply toilet paper (Inside joke)
    I have the original in MS Pub format if you would like to edit.
    • JR2ALTA
      • Feb 2010
      • 2017
      Originally posted by mansart
      [ATTACH]47815[/ATTACH]
      You da man! Looks like the two halves were about to separate when you ended so it should suffice.
      • timroz
        • Oct 2020
        • 17
        I found this document from sharp that one of the other techs brought back from school.
        3070 fuser rebuild.pdf - Google Drive
        • havokprod
          • Oct 2012
          • 156
          Wow, there is no Web or cleaning roller on these!?
          • Andypraeuner
            • Jun 2013
            • 29
            There was for a short time a kit that could be ordered to add a cleaning web roller kit that could be added to these fusers. That was shortly discontinued since it was mostly useless. So they have a program in system settings that you run to clean the fuser. This brings me to the question about if anyone has found a solution for those customers that constantly have to have that fuser cleaning mode run due to black streaks and splotches from buildup on the heat rollers?
            • Blind Avocado
              • Jan 2021
              • 37
              Since Sharp changed the toner from the 60NT to the 61NT I have not had any problem with toner build up on the fuser belt or roller, but toner does build up on the belt separation plate. If it builds up too much the toner can break off and cause splotches on prints. Unfortunately the only way to clean it is to take apart the fuser which is not too difficult.
