Sharp AR-6023 toner indicator
  • Service@PRT
    • Oct 2016
    • 181
    Good Morning,
    Got some problem regarding solving the toner indicator with this machine. Here are the steps i made before posting.
    1. Change New OEM toner / after replenishing after 2 days same problem.
    2. Change Developer, reset the maintenance, clean sensor & change again the toner (OEM). After 5 days same problem.
    3. Do the maintenance for the machine.
    Check motor gear of developer and toner. Nothing unusual.
    Change Toner again. Change drum kit reset the maintenance and After 3 days same problem.
    Appreciate any help can get.
    Thank you
    Sent from my YAL-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • mloudy
    • Oct 2015
    • 767
    Re: Sharp AR-6023 toner indicator
    Have either of these been recorded?
    L4-70 Toner motor lock
    F2-64 Toner Replenishment Error
    • JLSam
      • Jun 2015
      • 605
      It would help... if you told us the "American Model". But not many "Sharp" techs on this site compared to Xerox/ Canon/ Hp. Normally, I would just ignore it if I don't recognize the model, but my curiosity let me look for the American equivalent, which is the MX-M316
      The above post is correct, for those two codes, because there are associated bulletins.
      MFP-TB-1267 for F2-64
      MFP-TB-1504 for L4-70
      I would add to look for an F2-40 historical error code, there is a bulletin on that too.
      MFP-TB-1939
      Good luck.
      • Service@PRT
        • Oct 2016
        • 181
        No record of this error.. its just normal no toner. And when replaced with new oem toner.. after few days toner indicator comes.. and the counter reading only have 46k so didnt check the developer yet on the first encounter i just guess bad chip. But when it comes the 2nd encounter.. replaced the dv and clean the toner sensor.. and new toner again. 10-01 is working and i saw the toner poured on dv.
        Toner replenishment came after 25 simulations.
