Does the drum unit for MX-5071, MX60NUSA, work in a MX-5070V?
  • Tonersniffer
    • Nov 2012
    • 74
    Or do I need to individually order the drum, blade, and primary corona for the MX-5070v
    Sources that I have conflict each other
    Thanks for your help
    tonersniffer
  • EasyRider
    • Jan 2015
    • 87
    Re: Does the drum unit for MX-5071, MX60NUSA, work in a MX-5070V?
    SM shows MX60NUSA for both models.
    I have ordered before and new Drum unit will not come with the MC or shaft, and drum of course.
    Good luck
    • hellcat
      • Jan 2012
      • 124
      The unit does come with drum mc blade and everything you need to go. Just installed 2 today, they work on all models MX-60NUSA MX 50 / 60 50,70, 71 N and V versions
      The 30/40 50 70, N,V series are suppose to be MX-40NUSA not entirely sure if there is a difference other than color of the plastic on the front of the units , Im usually to busy to experiment much.
      • Blind Avocado
        • Jan 2021
        • 40
        The difference is the charge unit. The 50/60 ppm machines have a self cleaning charge unit while the 40 ppm and lower do not. The drum unit frame has a spring loaded mechanism so the machine can tell the difference, The two units are not interchangeable.
