My customer says this popped on her MX-503N display today and unplugging and a reboot will not clear. The model has about 600K on it and has 1 more year under contract. It's been working great for years.
E7-42 in the manual says
Cause Image transfer trouble.Check & Remedy Check the connection state of the ACRE ASIC PWB
connector.
Replace the ACRE ASIC PWB.
The manual does not show an ACRE ASIC board and gives very little other info. All I can figure is that this board is the "Scanner function expansion PWB" (Option for N model) It controls compression and decompression of image data. Number 28 in the service manual.
Is this the correct board I should be replacing? I plan on taking an MFP PWB and scanner board with me also. It's frustrating that the error and manual say it's a certain board then call it something else in the list of PWBs.
Any help is appreciated. Thanks.
connector.
