Please help.I have ar-m350 show error code L8-01.Thanks
Error code L8-01
straight from the book my friend
L8 01 Content No fullwave signalReplace the power unit.
Detail Full wave signal is not detected.
Cause The PCU PWB connector or the power unit
harness is disconnected or broken.
PCU PWB trouble
Power unit trouble
Check and
remedy
Check connection of the harness and
connector.
Replace PCU PWB.
i myself have found in the past that it mostly will be caused by the PCU PWB
Detail Full wave signal is not detected.Replace the power unit.
PCU PWB trouble
Power unit trouble
Check and
remedy
connector.
Replace PCU PWB.
But when i disconnect the scanner unit and let it run as printer unit only, it show funny error code,sometime F2-00,H4-00 .I am without clue.Please help. Thanks.Comment
I solve the problem. ThanksComment
