Sharp mx m 654N
  • davebtech
    • Apr 2015
    • 176
    Sharp mx m 654N
    Never had this one before, when scanning checks, it won’t let you (paper goes through fine) just plain copying no problem.Thanks for any input. Almost forgot you can copy check and rescan it it works....
    Re: Sharp mx m 654N
    are you enlarging for shrinking the image?
    this is a security feature built into most units now a days.
    and use the flatbed instead of ADF
    • davebtech
      • Apr 2015
      • 176
      Re: Sharp mx m 654N
      flatbed is a no go also.any way to change defaults?not enlarging or shrinking
        Re: Sharp mx m 654N
        WHY is flatbed a no go? when making a copy select enlarge/reduce ratio.
        • mojorolla
          The Wolf
          • 2605
          Re: Sharp mx m 654N
          Security feature....checks, bank notes and stocks certs are prohibited. There should be a corresponding error in the job log.
          We had a naughty customer....
          • davebtech
            • Apr 2015
            • 176
            Re: Sharp mx m 654N
            • mansart
              • 852
              Re: Sharp mx m 654N
              Make sure you are scanning in black and white as well. Not color
              • ricohrice
                • Dec 2008
                • 42
                Re: Sharp mx m 654N
                Scan using the Mono 2 setting
                • Nachoman4life
                  • Oct 2007
                  • 212
                  Re: Sharp mx m 654N
                  google "eurion constellation", its on cash and some higher value checks
                  Where the heck is my spring hook?
                  • Blind Avocado
                    • Jan 2021
                    • 40
                    Re: Sharp mx m 654N
                    Make sure you scan in mono only, not in color. This is an anti-counterfeiting feature built into all new scanners as required by federal law.
                    • davebtech
                      • Apr 2015
                      • 176
                      Re: Sharp mx m 654N
                      thanks for all the great input!
                      • repn1999
                        • May 2010
                        • 310
                        Re: Sharp mx m 654N
                        on some machines you can get it to scan color if you put a sheet of paper on top of the check. i believe the guideline is that it has to be plus or minus 20 percent in size if color to prevent counterfeiting. mono should work regardless.
