Sharp MXB427w ( I think rebox Lexmark MB3442)
  • mansart
    • 852
    Fax button does not appear.
    • I can select and de-select "fax" on op panel and via the web interface under "home screen icons" settings
    • I've re set to factory default
    • I've enabled the initial setup routine on start-up routine and re-set up as if new.
    • machine receives faxes and can send if I create a shortcut
    Just no fax button so I can't do a one-off fax
    Anyone? Even a wild-ass guess would be appreciated.
    TIA
  • Hansen88
    • 1069
    Re: Sharp MXB427w ( I think rebox Lexmark MB3442)
    When I get a chance i will look but maybe firmware update?
    • mansart
      • 852
      Possible firmware....but all Sharp has is the original production firmware, which I reloaded to no avail.
      I did find this in the Lexmark forum....
      https://www.copytechnet.com/forums/l...7=#post1444404
      • mloudy
        • Oct 2015
        • 790
        There was a firmware update that caused this on multiple Lexmark models. Normally cycling the power restored the icon but on a few we had to do an out of service erase. Very random. Not only did the icon disappear but it even killed incoming faxing.
        Sharp will have to get the firmware refreshes from Lexmark a little quicker if they want us selling them.
        • mansart
          • 852
          Out of service erase took care of it for now.
          Did not dare to even try to upgrade with newer Lexmark firmware
          That adventure is for another day
          Thank you.
