Will a FK1 code stop a MX2640 from working?
  • Leebs14
    • Feb 2014
    • 457
    [Error Code] Will a FK1 code stop a MX2640 from working?
    I know when the FK3 lights up you have to go and replace the web pretty quickly before the machine stops working, but is it the same for a FK1? This customer is miles away and I would prefer to sort the Fuser out when I have something else in that area or will the machine stop which means I have to get there asap?
  • mansart
    • 852
    Re: Will a FK1 code stop a MX2640 from working?
    • Leebs14
      • Feb 2014
      • 457
      Hi thanks for reply do you know what the default setting is
      Sent from my iPhone using Tapatalk[/QUOTE]
      • mansart
        • 852
        Should allow continued use by default
        • Leebs14
          • Feb 2014
          • 457
          • mojorolla
            The Wolf
            • 2627
            If the unit will not PRINT, you need to go into the print driver, ports and uncheck the SMNP enabled box.
            This will put the machine back online for printing.
