Sharp MX4070 giving error code c4-40
  • danny464
    • May 2019
    • 81
    Hello, I encountered an error on a sharp mx4070 printer C4-40. I looked it up and saw that it was a TC PWB voltage problem. Is there any way around to solve this issue or will I have to replace the whole board.
    Thank You
    Re: Sharp MX4070 giving error code c4-40
    Thank You
    whole board
    • copiertec
      • Jan 2016
      • 2187
      Have you tried changing the PTC Unit, first? Have you tried swapping out charge units on the drums? Have you checked all the connections going to the TC PWB? Check the 24v fuse on the TC PWB. If all else fails you need to change out the MC PWB.
      • EasyRider
        • Jan 2015
        • 85
        Had the same error this week on one of those.
        I had 24v at both the MC and TC PWB conn's.
        Replaced TC PWB and all is good.
        Never did find that pesky 24v fuse. Must be a little bugger.
          Probably a surface mount fuse. You shouldn't try to replace it. Just swap the board in question.
