Sharp MX-B350W - hangs (2 units in a network)
  • Europanels
    • Jun 2021
    • 2
    [Misc] Sharp MX-B350W - hangs (2 units in a network)
    Hi there,
    I'm having troubles with two Sharp MX-B350W in my network (same problem occurs on both). They work fine until they hang, and these hangs are very often (usually after a few or several dozen prints). I'm not getting any feedback from the printer, there's no trace in logs, no error messages, nothing that could help me diagnose the problem. The printer just freezes on the screen that's being displayed that moment and there's nothing I can do, but I can still access it through web admin panel.
    One of those printers has been updated to newest firmware version and it didn't help.
    One more clue - when I disconnect the printer from the network, it just works fine. Also, other printers (not Sharp's) work fine in that network.
    What might be the cause?
  • boutn
    • Jun 2016
    • 541
    Re: Sharp MX-B350W - hangs (2 units in a network)
    Originally posted by Europanels
    Hi there,
    You could try SIM 55-3 SW2 BIT7 change to 1
    • Europanels
      • Jun 2021
      • 2
      Thanks for your reply, although I found it a little too technical. Where and how should I change it?
      • boutn
        • Jun 2016
        • 541
        You can change it by calling your Sharp technician
        • mloudy
          • Oct 2015
          • 780
          What does this enable/disable? I have a pretty good list of SS settings and changing SW 2 bit 7 isn't listed.
          • 40yearsplus
            • May 2020
            • 113
            List of Sim 55-3
            found in CTN forums, don't see what applies either?
            • WackyJack
              • Feb 2021
              • 82
              Hi there,
              Because it only does it when connected to the network, I would look for IP address conflicts or corrupt print jobs on someone's PC. Maybe a laptop that is brought in later in the day or a computer that is turned on later than the rest. When it is turned on and connected to the network, it tries to reprint the corrupt job, and freezes up the machine.
              • mojorolla
                The Wolf
                • 2604
                Are the print drivers installed locally or are they shared from a server ?
                In the print driver, under Printer Properties, port tab, change the port type to LPR from the default of RAW. Click the box for byte counting, name the queue, then click Apply.
                You can also run 67-17 to flush print memory BUT this will dump SMTP / scan to email settings as well and I only use when I have to.
                • boutn
                  • Jun 2016
                  • 541
                  It disables power save functions or something like that.
                  We had a few customers where the printers kept locking up, only solutions was hard reboot.
                  No problems since...
