MX-3060V - Color copy lines
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 62
    Hello there !
    I'm having some problems with an MX-3060V, customer called because of lines on the copy's.
    I personally just thought the glass needs some cleaning, but then I saw these lines.
    They only occure on Color copy's, b/w everything is fine, I've never had this problem.
    Perhaps someone here got some suggestions ?
    I hope you can see enough in those pictures:
    - 64-01
    - 22-06
    Thanks in advance !
  • copiertec
    • Jan 2016
    • 2209
    Re: MX-3060V - Color copy lines
    What have you done to try to correct the lines? What is the life on the drum kits? Have you performed a calibration?
    • OlliK1969
      • Nov 2016
      • 311
      • CroceL
        • Jun 2020
        • 62
        Sorry guys I forgot to mention it only happens when using the scanner (copy/scan), I just used two examples for copy to show here. (64-01 and 22-06)
        But I've already replaced the CCD and it fixed it.
        Thanks anyways !
        • kdr363
          • Apr 2019
          • 63
          Does that model have a DSPF or RSPF? If DSPF, what would a 2 sided copy thru it look like?
          • CroceL
            • Jun 2020
            • 62
            3050 & 3060 (same for 51/61) generally come with just a RSPF.
            But theoretically one side should be fine with a DSPF.
            • ridgemill
              • Sep 2017
              • 190
              Do a full optics clean; both sides of the glass, scanner mirrors, & lens. If it still occurs you could be looking at faulty SCU; or ribbon cables are loose.
              • JLSam
                • Jun 2015
                • 605
                Only in copies? Strange.
                Looks like... a smudge in the mirrors, or could be that CCD unit.
                More importantly, what does your scans look like? When you scan as a PDF, what does the document look like on the PC? If there are no image quality problems on the scanned document, then you're looking at a print engine problem.
                • CroceL
                  • Jun 2020
                  • 62
                  Thanks anyways !
                  Thanks guys, but its already fixed.
                  It was indeed the CCD unit.
                  Is there a way to mark the thread as solved ?
