Sharp Mx2310 Printer calibration
  • chris1973
    • Mar 2021
    • 2
    [Electrical] Sharp Mx2310 Printer calibration
    We made the printer calibration on Sharp Mx2310.
    It is not ok, it show littel white lines ( like missing shadows)
    Chenged toners , drums , tranfer blet , fuser unit.
    I attached the printer calibration to see the defect
    Thanks for who will help me
    Chris
  • Prints Charming
    • Aug 2019
    • 189
    Re: Sharp Mx2310 Printer calibration
    That problem could quite easily be isolated to one of the following: Noise on Black Drum Motor or Faulty LSU Diodes.
    The CMY drum Motor is the same part as the Black drum motor. Swap these around and compare results. May need both drum motors replaced. Check the dev units are rotating smoothly without excess load or noise.
    The LSU has had 4 part updates since first production, and the LSU Mother PWB has had a few as well. Reinstall the LSU and Mother PWB into place to correct any possible loose connections. You may need new LSU or Mother PWB.
    Also, check the firmware is up to date. An early version 7 update had some corrections for laser power and fine line reproduction.
    • chris1973
      • Mar 2021
      • 2
      Thanks !!! there isn't any noise we will try by the firmware update
      • jp74msj55
        • Oct 2014
        • 150
        Chris
        Try running Sim 64-4 and change first setting to 3.
        It will print out individual colors.
        May narrow it down for you.
