Sharp MX-5071S Fin_Err
  • westoneking
    • Aug 2023
    • 8
    Hello everyone, I have a Sharp MX-5071S with a FN29 finisher getting intermittent/ returning problem of Fin_ERR in the jam logs. Reseated the finisher plug and that seemed to fix it for about a week. Then it happened again, cleaned the finisher entrance sensor and that also seemed to make it work again for a couple more weeks no jamming. Now it's back. Any ideas?
  • boutn
    • Jun 2016
    • 540
    does the machine have a punchunit?
    • westoneking
      • Aug 2023
      • 8
      It does not have a punch unit. Just replaced the finisher control board. I was mistaken. It's an fn28. The control board didn't fix it. I also replaced the entrance sensor. No dice
      • sharphead
        • Aug 2009
        • 285
        Just out of interest how is the punch unit related? We had one throwing this jam code for a week, then it stopped and it had a punch unit
        • westoneking
          • Aug 2023
          • 8
          School started back up and now I have replaced the Finisher control board, the machine control board, finisher entrance sensor, did a CN update, I'm not sure what else to even look at at this point.
          • Hansen88
            • 1053
            I have never came across this code before. Everything I find about it says firmware. I know you did that already. Hope that fixes it.
            • tedtech
              • Dec 2011
              • 50
              I've seen this before....Theres a sensor at the entrance to the finisher that gets coated in dust. Clean that thing off and see if that fixes the problem
              • harps05
                Field Service Engineer
                • Mar 2012
                • 111
                110% in agreement here with Ted. Have had the same problem and the same frustation. The solution was very simple in the end.
                • Mittle Lix
                  • May 2024
                  • 5
                  Agreed on the finisher entrance sensor, everytime i've had this code, cleaning the finisher entrance sensor has fixed the problem.
                  • odinp
                    • Jun 2019
                    • 30
                    This finisher inlet sensor is also my bet, the inlet plate above the sensor is also very flimsy and easily bent, Ive had that cause finisher jams too,
