Hello, anyone knows if the Sharp oem MX565 toner will work with the HP MFP S956 equivalent. Thank you for you help.
HP MFP S956 SHARP TONER
No idea, but you can always try it if you have a MX561NT cartridge laying around. The machine might just say that it isn't an OEM HP cartridge but still work, or it might not work at all, since HP has cracked down on non-OEM toner usage. Some models have a firmware version that prevents the machine from using non-OEM toner
