Sharp MX-5110 DOCUMENT FEEDER PULLING IMAGE
  • IBS Copiers
    • Jun 2021
    • 2
    Been working on a SHARP MX-5110 and every few weeks the document feeder will pull the image to where it isnt legible and haven't been able to figure out what exactly is causing the issue has anyone else experienced this? And if so what do you recommend ? Ive replaced the feed rollers, clutches and motors.
  • mojorolla
    The Wolf
    • 2611
    Re: Sharp MX-5110 DOCUMENT FEEDER PULLING IMAGE
    I always pull these completely apart and clean everything. These unit can hold an ungodly amount of paper dust, especially around the turn to the slit glass where the registration sensor is. If you only did the feed clutch, may want to look at the registration clutch as it controls when the page arrives to be scanned, SRRC is the clutch name I think....
