BP70C55 waster toner not reaching yeild
  • mommok
    • Jul 2014
    • 48
    We installed a new bp70c55 a few weeks ago. since install the machine has a total of 95K clicks on it. the machine is averaging about 20k before it asks for a new waste toner. according to manual the waste toner bottle yield is 50K. any ideas on what to check to make sure supplies are reaching appropriate yield?
  • nanohitmen
    • Apr 2019
    • 114
    shot in the dark here, but have you checked that it isn't leaking dev?
    • yurisan
      • Dec 2007
      • 116
      How many toners has it consumed in 95K? Manufacturer's yields on toner & waste toner boxes is based on 5% image area - which is a tiny splash of color to go with a double-spaced page of text. It is more realistic to expect to achieve 50% of those yields for many operators of the machine - that gets you to 12K for color & 20K for black. The Sharp toners have a pre-mixed amount of developer in the toner to account for the developer normally lost during the printing process - their toner's not light weight. A rule of thumb is you'll need a waste toner box for every set of toners.
      • nanohitmen
        • Apr 2019
        • 114
        I find your statement to be right on the money, I just did some deliveries today, every toner set had 1 BP-HB700 with it.
        • Mittle Lix
          • May 2024
          • 5
          We upgraded a client from a series of MX5070s to BP70C55s.
          After a couple months we had their IT team speak to us in regards to swapping out Waste containers at a higher rate, investigated and found that on average we were swapping out waste containers between 20,000-23,000s pages.
          Have noted similar usage amounts from all of our BP machines in the field. We consider this the expected yield from this series of machines.
