Scan to email 365
  • davebtech
    • Apr 2015
    • 176
    Scan to email 365
    Anyone ever have connection issues , it’s a mx 2651 so encryption shouldn’t be any issue , maybe in there 365 email box settings screwing things up ? Any help appreciated Dave
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    When you say connection issues, what error are you getting? i have had a couple of machines where i was having difficulties with authentication. I made use of the Oath method rather than using smtp, not sure of what issue you are having though.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • Sven94
      • Sep 2023
      • 28
      It has to be a Standard licence from Office 365 NOT exchange. In the admin center you have to check the SMTP Auth.
      • nanohitmen
        • Apr 2019
        • 115
        also check firmware there's been releases to address issues like that
        • JLSam
          • Jun 2015
          • 605
          Set up is pretty much like this from one of our MFP's in the field. No issues.
          • davebtech
            • Apr 2015
            • 176
            App password ? Isn’t scanner@ abc company password ok? Is smtp usually checked in 365 admin by default?
            • AlexandruMG
              Service Engineer
              • Jul 2024
              • 14
              Hi davebtech,
              Difficult task for you mate! First of all you must do update of firmware to the lastest version and after that take a look to attached file and let us know if solved the problem.
              The machine 100% is ok. You can do several test with a gmail account, imap or any other smtp server and you will see is working fine.
              Regards,
              Alex
