MXM283N Lines on copies (RSPF)
  • PillarWizard
    • Dec 2023
    • 31
    Currently struggling trying to remove a line from copies. I believe its a simple fix and I may be overthinking/overlooking it.
    Details:
    -Direct prints are fine. They come out clean with no lines
    -Making copies from the glass bed is fine, no lines.
    -Making copies through the top feeder is when the lines appear (see attached)
    -Quality of the line is intermittent, as sometimes its a clear line or at times its faded/barely noticeable.
    -Cleaned the feeder glass (back and front)
    -Cleaned the copy lamp (I doubt it was the cause but did so anyways)
    -Replaced the feeder glass
    -Cleaned the plating directly above the glass feeder when closed.
    -Applied liquid correction fluid certain parts of the plating
    -The line appear on the same spot regardless if the document was scanned landscape or portrait through the feeder. (Note: This is what's throwing me off)
    Any ideas would be much appreciated. Thanks -PW
    20241015_081815.pdf
  • harps05
    Field Service Engineer
    • Mar 2012
    • 112
    Looks like the lead edge of the original. I'd also clean all feed rollers in the ADF.
    • PillarWizard
      • Dec 2023
      • 31
      [Solved]
      harps05 is correct, it was the lead edge of the original. I've adjusted the SPF in sim 50-06 and prints are coming out clean.
      Thank you for the knowledge. -PW
