Offset Function not working MX3560v
  • sharphead
    • Aug 2009
    • 285
    Bit of a strange one.
    Had a customer report offset function not working.
    On arrival function not selected. when turned on not working.
    Tried in simulation 6-1 OSM motor doesn't move and OSM highlight turns off immediately.
    Harness and connectors looked fine, all reseated. OSM motor changed, no difference. PCU PWB replaced. No change.
    Any ideas?
  • Hansen88
    • 1053
    I think it can be turned off in the print driver also. This would not account for motor not working in sims though.
    • Hart
      • Feb 2024
      • 366
      55-1 SW24 7 to use the copier without finisher or offset motor.
      Check if it's not activated.
      • leo34staffs
        copierman
        • Aug 2007
        • 503
        Defo this, i had the same a few years back, swapped motors etc, turned out to be this!! and it was a new machine!!
        Networking skills are advantageous but use of a 3m vacuum cleaner is essential
        • Hansen88
          • 1053
          Thanks for this info. We have a bunch of exit trays but no motors. Nice to be able to turn off the motor.
          • sharphead
            • Aug 2009
            • 285
            Thanks, will check that simulation soon. It's a strange one.
            • sharphead
              • Aug 2009
              • 285
              So the above mention switch was the problem. Thanks so much
