Sharp MX-7=6071 E6-11 code
  • AndresM
    • Jan 2016
    • 37
    Hello , I'm working on this Sharp MX-6071 , I found a paper clip on top of de ADF control board which I replaced with the new one from Sharp, I tried to run Shading calibration using the correct calibration Sharp tool without any luck, so I have replaced the ADF optical unit too but still can't get the machine to calibrate. I have checked all the bulleting related to this code and done everything I can.
    Any help is greatly appreciated. Thank you!
    Andres.
  • iHateSharpFusers
    • Jul 2024
    • 38
    If you used a new part # for the DSPF PWB, did you also use the updated part number for the Lens Unit? If not, that is your problem.
    • iHateSharpFusers
      • Jul 2024
      • 38
      For American MX6071
      Updated Lens Unit: CPLTM8694DS85
      Updated DSPF PWB: CPWBX2429DS72
