RED READER JAM CODES
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    I have the red reader software and i have some jams i cant decode.
    I have downloaded the red tech tip 1472 with the codes list but they dont match up to what im seeing and tech support has no answer yet for me.
    jam codes are 2e1 and 2c1 (taken from a mx 6240 and an mxm6070)
    does anyone have a more up 2 date jam code list for the red reader?\
    see below for cut / paste
    Number of Main Body Jam Histories = 4
    MB Jam Histories
    MB Jam History 0
    Jam Code = 2E1
    Event Date and Time = 10/14/2021 11:55:28 AM
    Total Counter (valid output counter) (B/W) = 412297
    Total Counter (valid output counter) (Color) = 313380
    MB Jam History 1
    Jam Code = 2C1
    Event Date and Time = 10/12/2021 8:47:50 AM
    Total Counter (valid output counter) (B/W) = 411351
    Total Counter (valid output counter) (Color) = 312325
    I fix copiers ...Well Sorta
  • mloudy
    • Oct 2015
    • 773
    Re: RED READER JAM CODES
    Do you still not have MICAS in Canada?
    If not it would be intresting to know it one of your machines could be registered in MICAS and data collected from it.
    I have seen weird jam codes showing in MICAS that I can't find info on. I have asked MICAS to address it but they said more than once they are waiting on Japan. I have never heard of RED Viewer.
    • mloudy
      • Oct 2015
      • 773
      From MICAS on a MX-5051
      9/28/2020 1:14 Main Body or Original Jam C1PFD_N1 (2C1)
      9/1/2020 9:55 Main Body or Original Jam C1PFD_S1 (2E1)
      • fireater
        • Apr 2006
        • 253
        ya .. no micas here
        are you guys a sharp dealer or sharp direct?
        red reader can be downloaded from the sharp tech support web site (sharp.ca) not sure about sharp usa.
        it decodes those files attached to the dealer alert status
        • mloudy
          • Oct 2015
          • 773
          Small Sharp dealer. I searched IDNC Service for RED reader and got no hits. I assume it isn't available because we can use MICAS.
          MICAS is really useful for many reasons. I can't understand why Sharp won't launch it in Canada. My techs can do a little research before heading out and take everything they need. There is also a mobile app that is nice.
          I can get a SN from a seller of a used machine and plug it into MICAS. If was set up to report I can see the history of the machine and determine if ran well before I commit to buy it.
          • fireater
            • Apr 2006
            • 253
            was curious of the cost
            is it per machine ?
            or just flat fee?
            or x dollars / 100 machines?
            also you mentioned setup.
            I understand a program is installed on a system in the customers office is this correct? what else is involved?
            lol i emailed micas and they never even replied to me. :/
            • mloudy
              • Oct 2015
              • 773
              Completely free.
              Some dealerships will not use it out of fear that Sharp Business Systems could swoop in their area and have a list of machines already. I know enough about SBS not to fear them taking our accounts plus we are very rural and they would not open a branch in our territoy.
              There are two ways to register a machine and this is how we do most of them. Create the Customer in MICAS, you could call them anything you want if you wanted to throw off SBS. Register a machine using the Model and SN. Set up the machine to send alerts to MICAS on a daily basis. Enter the MICAS email address in the Dealer slot in Alerts Messages and Status Messages. The daily send is used when nothing happens in 24 hours. All of the events trigger data to be sent to MICAS immediately. This method of registering allows me to see the history of a used machine before I buy it as long as it was set up to send to MICAS previously.
              The other method to register is to install an Agent at the customers location. We use this method when there is a mixture of Sharp and Lexamrk devices that we service. The Agent will pick up any network printer/MFP but we only use it for our equipemnt. This method will fail if the PC or server with the Agent is replaced.
              • tsbservice
                Field tech
                • 7955
                Interesting thread...altough I cannot contribute.
                It appears from Sharp Us that actually RED is part of MICAS system
                MICAS is a cloud-based device management application that uses Sharp's Remote Email Diagnostics (R.E.D.) to collect device data and alerts.
                MICAS | Document Systems | MFPs | Sharp for business
                • mloudy
                  • Oct 2015
                  • 773
                  What is really interesting is that when I use the mobile version I can enter just a serial number of a machine we have never registered and isn't our machine and it pops back the model# along with infomation like total meter, toner level, events, firmware level and the last time there was a transaction. I assume that these machines have been reporting to gather this info but it isn't registered under our dealership and I can still get the info.
                  How useful is this? I got a list of off-lease equipment today and one of the machines I wanted to buy was listed with a 38K meter. I plug the SN in MICAS Mobile and it is showing 137,897.
                  • fireater
                    • Apr 2006
                    • 253
                    sounds like someone knows how to reset meters. check the paper tray counters and see if they add up to the total meter
                    • mloudy
                      • Oct 2015
                      • 773
                      Either that or the people checking in the machines dropped a 0. I sent the seeler a request to double check it.
                      Do the Canadian Sharps have the Dealer E-mail Status Message List box in their webpage? This is where we enter the MICAS email.
                      • tsbservice
                        Field tech
                        • 7955
                        I would think one dealership can see only machines under own account. Apparently this system can be used like old paper works when we leaved service history on paper at the back of machine. Your competitors may use this sheet for their advantage. Same as here. Imagine another dealer checks your machine serial in MICAS and tells: Hey Mr customer - your machine has way too many paper jams, we can provide better service or similar...
                        • fireater
                          • Apr 2006
                          • 253
                          yes that dealer alerts is there. firmware between us and canada is same. we have an email account in there to get the R.e.d messages.
                          we can view them with red reader but the codes havent been updated in years. tech tip 1472 dated september 2010
                          Sharp Direct dealers in Canada uses Micas but not the independent dealers.
                          • mloudy
                            • Oct 2015
                            • 773
                            I just put a random SN in MICAS Mobile and it came back with where the copier is installed. This info would have been entered by the dealer when the machine was registered. Still weird that I can see that info and the history of the machine. This only works with the mobile app. If you try and register a machine online that another dealer has already registered it will tell you it is already registered and and fail. If it is a used machine we have bought we have to email MICAS who then contacts the previous dealer so they can delete it.
                            I would be ticked if SBS had access to MICAS and we did not here in the US.
                            • fireater
                              • Apr 2006
                              • 253
                              one last think if you can help me once more then im done
                              mx6240
                              jam codes 521,46df,139f,501,100,602
                              seemingly random codes 15 in a week
                              can you decipher these for me?
                              tks in advance
