L4-08 sharp mxm850
  • haysam
    • Oct 2021
    • 4
    L4-08 sharp mxm850
    I have a big problem with the Sharp mxm850 copier - the code appears l4-08 (WASTE TONER TRANSPORT PIPE LOCK), and I changed the entire exhaust pipe and the switch for waste exhaust was changed - the rubber belt of the gears in the machine was changed - all of that and the code still remains I do not find a solution - other than that I send the company that produces the same product, and you are the makers of the machine - I ask you to send the solution - and do not tell me to go to the merchant - I am the merchant himself and I do not know the solutionโ€‹
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Re: L4-08 sharp mxm850
    Is the Drum rotating?
    sim 6-1 and watch everything rotate
    sigpic
    • haysam
      • Oct 2021
      • 4
      The dram rotates half a turn and then stops and the error appears - and when sim 6-1 is used, everything works very efficiently - but the malfunction still exists
      • oscarconil
        • Oct 2021
        • 27
        check the sensor
        • haysam
          • Oct 2021
          • 4
          Originally posted by oscarconil
          check the sensor
          which sensor ??
