SHARP MX-B557F
  • txonsov2
    • Aug 2023
    • 18
    [Error Code] SHARP MX-B557F
    Hello everyone I have a machine Mx-B557F, which is giving me many failures from time to time comes out the kernel error 900.00, the machine restarts alone in the middle of a print or if you fall asleep sometimes does not wake up and this error comes out if anyone has happened or know how to fix the firmware is updated to the latest version available 230.217, sometimes it fails with 10 sheets and other times you throw 100 and they all come out. Thanks in advance! Good day and happy new year.
  • OlliK1969
    • Nov 2016
    • 311
    Hi
    You can try downloading newer firmware from Lexmark's website. It is the model XM7370
    Good luck
    MXTGW.230.329 726 MB newest Versionโ€‹
    • txonsov2
      • Aug 2023
      • 18
      It seems that this update in the sharp system was not then I thought it was the last, it seems that if it has worked as it has not yet come out the error and a light came on the board that soon turned off with the previous version. Thank you very much!
      • txonsov2
        • Aug 2023
        • 18
        it is true that with the last update it seems to have improved but it still does the same thing but in longer time.
