Light copies MX-C507F
  • glimmer1980
    • Aug 2014
    • 105
    Hello,
    I have a MX-C507F that only show light copies when printing black. The color copies are good. The black image / dev unit are allready been changed.
    Has anyone encountered this before?
  • mloudy
    • Oct 2015
    • 791
    Re: Light copies MX-C507F
    Open the right side toner door and make sure the front side post that opens the shutter on the black toner is not broken off. We have customers that find a way to snap this post off. The posts are not available so it requires the entire door to be replaced. Once you have replaced a door you will then have 3 good posts to use down the road.
    • glimmer1980
      • Aug 2014
      • 105
      I just checked the pins on the door, but they are all there, no broken ones.
      • boutn
        • Jun 2016
        • 552
        I've noticed these machines print very light.
        If you go to the webpage you can darken your prints.
