Sharp SF-7900
  • jerilee001
    Sharp SF-7900
    Code H4 is coming up on copier....can anyone help? Any info. would be appreciated..
    thanks,
    jerilee
  • Wild Bill
    • Jul 2005
    • 774
    H4
    H$ error cod is a fuser error. This is probably a thermal fuse. You then have to reset it with cioi 14. It also could be a lamp and or a thermistor.
    Izzy
    • bilyahn
      • Dec 2006
      • 1470
      H4 is generally a fuser problem. Either the fuser did not heat up in time. If you hold down the copy button it will give you a 2 digit sub code (01, 02, etc). Check your lamp to see if they are coming on.
      Good luck. Bil
      • Lawton
        Could be lamp
        Check to see if lamp comes on, if not could be lamp.
        • Wild Bill
          • Jul 2005
          • 774
          A little redundant don't you think?
          Izzy
