Spooling jobs with PaperCut
  • Connor
    • Nov 2021
    • 5
    [Misc] Spooling jobs with PaperCut
    Hi All,
    Having a very peculiar issue with PaperCut and Sharp devices wondering if any one has had anything similar.
    > Client prints to a Virtual Queue
    > Client Releases Job at device
    > Machine pulls job down from print server
    > it fails to spool and fires hundreds of jobs to the printer. This happens even though it is a one page doc
    > it doesnt happen with test pages or smaller sized documents
    > PaperCut is on MF21.2
    > Drivers are official sharp
    > Machines on latest firmware
  • mojorolla
    The Wolf
    • 2606
    Re: Spooling jobs with PaperCut
    Sounds like it's pulling the entire virtual queue.
    Try this: Configure Secure Print Release to support multiple operating systems (papercut.com)
    • diedux
      • Jan 2017
      • 124
      If these "hundreds of jobs" are symbols, you should pay attention to a source (virtual) and destination (physical) queues drivers emulation (PCL6, PS, etc.). Never mix PCL and PS (PostScript) on queues.
      Keep in mind if you use mobility print, then jobs are rendered in PS.
      Lastly, it can be just a driver or document problem itself.
      • Connor
        • Nov 2021
        • 5
        SOLVED, Changed the port and it seemed to be working ok.. very odd
        Thanks anyway!!
        • diedux
          • Jan 2017
          • 124
          Thanks anyway!!
          Just curious. Changed port how? To a different IP or from PaperCut port to standard TCP/IP? Did you change a port on the virtual or physical queue?
