Sharp 6070 no color problem
  • lopakad1
    • Nov 2014
    • 69
    Well I have a weird problem later on a short 6070 doing calibrations and such the copy comes out absolutely perfect but when I make a copy of that calibration no color or very little color is present on the page also have the problem with printing from customers computer in color black shows up but no color shows up on page please help never ran into this before
  • kdr363
    • Apr 2019
    • 63
    Re: Sharp 6070 no color problem
    Forgetting about the customer printing and coffee-ing for now, how do test prints look? Sim 64-5 pattern 4 for example?
    If ok, how about 67-25 calibration page? How does it look?
    • lopakad1
      • Nov 2014
      • 69
      This is what I get Internal Print is fine but when I make a copy of it comes out like garbage even when the customer Prince after I scan it to them this is what it looks likeD09F81D9-D3FD-4753-97AE-92918732B5DD.jpgAA5E619B-3D8F-4908-B340-680359C4A9AF.jpgD09F81D9-D3FD-4753-97AE-92918732B5DD.jpgAA5E619B-3D8F-4908-B340-680359C4A9AF.jpgD09F81D9-D3FD-4753-97AE-92918732B5DD.jpgAA5E619B-3D8F-4908-B340-680359C4A9AF.jpg
      • kdr363
        • Apr 2019
        • 63
        And the 67-25 printout for print calibration confirmation?
        And the 46-21 printout for copy calibration confirmation?
        • mojorolla
          The Wolf
          • 2583
          Internals and prints are fine so you are looking at a CCD, scanner board type issue.
          Go into service mode and check the gain level of the CCD. If it is double digits, that is the most likely cause.
          Is the result the same through the document feeder and from the platen glass?
          • Prints Charming
            • Aug 2019
            • 189
            You've got a DSPF on that model. Place a good quality internal test print in the DSPF face-down, and perform a double-sided copy. That way you'll be testing the CCD/Optics/Control Board in the DSPF and isolate the issue to the Scanner CCD/Optics.
            Make sure you also run a 63-05 to reset the scanner adjustment values, and use the SIT Chart in 63-03 if you have it available.
            Reposition all harnesses from the scanner to the MFP Board.
            • tsbservice
              Field tech
              • 7955
              Yep DF and platen glass...may be different outcome depending. Reading and understanding manuals done well โœ…
              • bilyahn
                • Dec 2006
                • 1470
                Had something similar to this on an MX-5070N. After doing all of the above steps including changing out a lot of boards our tech rep finally suggested doing an end of lease procedure and voila everything was perfect. Something to try before you order a $500 board.
                Good luck
                Bil
                Here is the post I ran back in January
                MX5070N CQ issues when copying in color
