Sharp MX5111 Scanning Issues
  • youfster
    • Dec 2021
    • 3
    Hi everyone!
    Another day, another fun encounter with the old Printer
    Yesterday I tried to scan a document, and all that i got in return was a purple, fuzzy image. Not sure what the issue is, but I'm suspecting an LED isn't functioning during the scan.
    I did observe the printer whilst scanning and I can see the led white light scan across the document, but not entirely sure what else to look out for.
    Any advice would be greatly appreciated.
  • copiertec
    • Jan 2016
    • 2223
    Re: Sharp MX5111 Scanning Issues
    could be the ccd unit.
    • mloudy
      • Oct 2015
      • 791
      Try a 2 - 2 scan through the ADF and see if you get one good side and one bad side.
      • mojorolla
        The Wolf
        • 2639
        If the exposure setting is set to Auto, set it to something else. Have seen Sharps do odd things with auto exposure enabled. As suggested, a 2>2 scan is a good test and a scan from ADF and platen to compare results. If you want to get techy, enter service mode and check the gain readings of the CCD. A failing CCD unit will generally be double digits.
