Sharp AR6020DV
  • Abimotek
    • Feb 2015
    • 59
    [Misc] Sharp AR6020DV
    Hello, pls kindly advice what could be causing toner dusting on developer unit attached picture right top , (Sharp AR6020) will cover the under scanner glass, the copy will start fading top, attached picture. After I cleaned, several copies will still come back, pls advice solution
  • driving lots of miles
    • Jun 2016
    • 399
    Re: Sharp AR6020DV
    Need to check Black Drum and Charge grid. Most likely need replaced.
    • JLSam
      • Jun 2015
      • 605
      Re: Sharp AR6020DV
      +1
      Don't forget to clean LSU window after replacing Black Drum/Charger/Blade. Also, make sure DV seals are good, and straight, there are some models where the seal is warped, and was creating spitback and spilling DV/toner dust creating the same problem seen in the posted pictures.
      Also, for next time, posting a copy of the 22-6 will get better answers.
      • Abimotek
        • Feb 2015
        • 59
        Re: Sharp AR6020DV
        Originally posted by JLSam
        +1
        Sorry I don't get what's meaning 22-6🖕. For the clean LSU under glass, after removed developer unit right?
        • mloudy
          • Oct 2015
          • 790
          Re: Sharp AR6020DV
          A 22-6 is an internal print out with all kinds of info. Enter SIM mode and print it.
          The LSU window is directly above the drum and can been seen after you remove the drum. It will be a narrow piece of glass.
          • digital_yetch12
            • Jan 2022
            • 1
            Re: Sharp AR6020DV
            Best Digital Marketing & Web Development Company in India
            • Abimotek
              • Feb 2015
              • 59
              Re: Sharp AR6020DV
              Pls how to enter SIM, print 👇
              • Craigcul
                • Aug 2017
                • 70
                Re: Sharp AR6020DV
                Hi there the Sharp AR-6020 range of machines does not have 22-06 printout all counters need to be checked manually.
