arm-450n memory
  • DINGO
    • 661
    arm-450n memory
    Hy
    There are same advantage to do upgrade of memory in a arm-450n??
    because have only 64mb, but already have a hard disk of 40GB.
    If yes , wat is the advantage??
    thanks
  • bilyahn
    • Dec 2006
    • 1468
    Haven't had any reasons to upgrade the memory in these machines. They seem to work fine for the most part. Most of our clients are not doing major print jobs or massive pdfs though.
    • lky1978
      • Mar 2009
      • 476
      if u use a lot of up to A3 size for network scanner then you need to upgrade the memory
