MX3571 with H7-10
  • glimmer1980
    • Aug 2014
    • 105
    MX3571 with H7-10
    Hello,
    The customer has a MX3571 with nearly 4000 copies. Yesterday it got a H7-10 message. After turning the machine off and on it turned into H4-00. We replaced the fuser. Unfortunatly the machine goes into to a paper error without any paper to find in the machine.
    Has anybody have an experience with a H7-10 code?
    Regards,
    Ramon
  • Hansen88
    • 1066
    Re: MX3571 with H7-10 code
    Originally posted by glimmer1980
    Hello,
    Regards
    Ramon
    there are two bullitens for that code and model. First is a firmware update and second says to swab out the fuser and machine main connectors with alchohol. Hope these help. P.S. I am talking about the main fuser connector and the other half of connector in the machine.
    • ZachHarbour
      • Jun 2021
      • 23
      If none of what is stated above resolves the issue you can slightly raise the fuser temperature in sims. I would only do that as a last resort though.
      Best of luck
      Zachary Harbour
      Hogland Office Works
      zach@hoglandcopiers.com
      • glimmer1980
        • Aug 2014
        • 105
        For the engineers that also get this error code. We replaced the HL PWB and it solved the problem.
